1956 Cadillac Sadan AC
Started by caddie c, October 17, 2016, 06:27:52 PM
caddie c
Does anyone have or know were to find parts for a 1956 ac controller, switch,rheostat and driver side fan motor,or know how to restore the electrical.Thank you
J. Gomez
Johnson,
Which pieces are you referring the fan speed control rheostats or the temp control rheostat?
If you have the A/C dash control the fan speed controls can be clean and put back if the element still intact, I just refurbished one not too long ago.
If the temp control rheostat insulator in broken or the wiper on the lever which rides the temp control is bad, then it will be a bit more difficult to get them back.  :(
Any pictures you can share of yours?   ???
J. Gomez
CLC #23082
caddie c
did you take rheostats apart or cleaned them intact with electrical cleaner,my rheostats are not broken was not getting ohm readings.My driver side blower motor not working passenger side appears to be OK.will post pictures tomorrow camera not connecting.
