Guys I can't seem to get my carb tuned properly. It has been rebuilt by myself with the aid of my father in law.
The jets squirt fuel great, you can see it when you pump the throttle. Fuel pump and fuel pump push rod are new, and in good working order.
I pump a few blips of gas in, turn the key and it fires right up, only to die about 3 seconds later.
I am missing the choke connecting rod, and the hot exhaust tube that connects to the choke. Manually holding the choke twisted to the right and having my wife turn the key gives the same results.
Id like to play with the mixture screws and the idle screw, but I'd like to start at factory correct settings (for example, tighten them up and back out 1.5 turns.). Not sure what they are supposed to be.
Any help would be great. Thanks
