OPGI 64 Cadillac trunk cardboard
Started by kokerscad, October 28, 2016, 10:34:31 PM
kokerscad
So I have a 64 fleetwood 60 special, I need new trunk cardboard, OPGI has it for a 64 4 window sedan DeVille, has anyone used it or knows it if will work for my fleetwood? The pieces look correct, but I'm Leary of purchasing it, I asked them and they said they don't know it it will work, maybe one of you guys do...
C.Dias CLC#27578
1965 DeVille convertible
1964 Fleetwood 60
russ austin
The parts book shows that they are different part numbers, but what the difference is, I don't know.
R.Austin
cadillacmike68
Fleetwoods and DeVilles had the same wheelbase and OAL in 1964, so unless there was a trim material difference (I don't think there was) then it should fit fine.
"Cadillac" Mike
jagbuxx #12944
On Fleetwood series, the sideboards and hinge cover boards are carpeted. Not on deVille or Series 62
Frank Burns #12944
61 Coupe Deville Bristol Blue
41 Series 61 Deluxe Coupe 6127D Black
08 STS 3.6 1SC  Thunder Gray
16 GTI Gray
03 T-Bird Black
19 Tiffin Phaeton 40AH
07 Corvette Blue
20 MB S450 White
"Whatever the occasion, there
is no better way to arrive than in a Cadillac.
russ austin
That has to be it. The Fleetwood and Eldorado have the same part numbers for the trunk liner.
It will look original, once you cover the panels in the fabric.  SMS auto upholstery has the original pattern for the trunk fabric.
R.Austin
kokerscad
Ok this is what I was figuring, my fleetwood has carpet on the panels and I knew the devilles and lower series didn't, no harm in ordering the ones from opgi, checking to see if they are correct, then re carpeting, thanks for the input
C.Dias CLC#27578
1964 Fleetwood 60
Eric DeVirgilis CLC# 8621
Fleetwood & Eldorado also came with spare tire cover of the same cloth used on the floor and side panels.
Jason Edge
You can see examples of the 1963/64 cardboard and fabric trunk interior and more details on what was covered in fabric on the 1963/64 Cadillac "Trunk Compartment" help page at http://6364cadillac.ning.com/profiles/blogs/trunk-compartment-interior
Jason Edge
Lifetime Member
Exec Vice President
CLC MRC Benefactor
2002 Escalade EXT - Black
