carb replacement 1953 cadi sedan
Started by gdtogo, November 02, 2016, 12:23:09 PM
gdtogo
looks like I need to replace the carb, been rebuilt but car still does not idle
people who have replaced carbs what have you used recommend  might as well buy new and save original
thanks
Bobby B
Steve,
Have it rebuilt by a pro and you'll have no issues. I have someone for you if interested. You won't have any more problems, but are you sure it's "Just" the carb? Fuel pressure? Timing? Worn Ignition parts? Etc.?
  Nothing better than the correct carb unless you're building a Hot Rod.
        Bobby
1968 Mustang Convertible
1973 Mustang Convertible
1969 Jaguar E-Type Roadster
1971 Datsun 240Z
1979 H-D FLH
55 cadi
I agree with Bobby.
There are a few things that can cause that not just the carb.
Check fuel pump, make sure it's working good.
Timing.
Points.
Check your tank, see if it's good, meaning has good gas not dirty gas, put a filter before the fuel pump and see what it looks like.
Jason
1955 Cadillac sedan series 62
2005 Cadillac deville
Jay Friedman
check that there is not a vacuum leak.
1949 Cadillac 6107 Club Coupe
Decatur, Georgia
CLC # 3210, since 1984
55 cadi
Jay is correct also,
Forgot to mention. That will affect it also.
Cap the two hoses going to vacuum manifold until you have replaces the air hoses, or checked that they are good but should probably replace all anyway if they are not new.
Jay Friedman
I would also check the hoses in the windshield wiper system and the antenna system, as well as the intake manifold gaskets and the gasket between the carb and the manifold.
Decatur, Georgia
