Location of Fuses on 1950 Cadillac Gauges not Working
Started by 50Cad62, November 11, 2016, 12:20:52 PM
50Cad62
Could someone please answer another question? My gauges aren't working on the 1950 Cadillac. I think it is a ground, or the fuse. I can't find the fuses. Are they behind the driver's kick panel? Thank you.
Bob Hoffmann CLC#96
I would suggest you buy a owners manual & a shop manual. They will help you with working on your car.
Bob
rghobden
The gauges are not fused so I would suggest you look for a bad ground since you say none of the gauges are working.  Do your lights in the speedometer cluster work?
Russ Hobden #1235
Russ Hobden, CLC #1235
50Cad62
Yes, I must buy an owner's manual, and, a shop manual. I will. No, the lights in the speedometer cluster do not come on. Not even when the headlight switch is turned.
johnwalker
The dash light rheostat in the headlight switch goes bad. Corrosion usually.
1949 6207
1950 6137
1940 6019S 3 window coupe
1948 olds 98 sedanette
1947 diamond t pickup
1930 model a roadster/392 hemi
1949 cadillac woodie (was a buick)
1933 chrysler royal 8 3 window coupe
1977 930
1987 911 cab widebody
1969 911E
J. Gomez
Maybe a 1951 wiring diagram would help you in your dilemma in the interim, I would guess the 1950-1951 would be the same ???
Just in case here is the one for 1951.
I would suggest as others have to temporary connect a wire from the instrument cluster over to a good ground source to verify. The dash lights and gauges do pick the ground path at the cluster.
Good luck..!
J. Gomez
CLC #23082
50Cad62
