1973 Deville Cowl tag decode
Started by Robert666, December 03, 2016, 09:09:51 AM
Robert666
Hello, I have a 1973 Coupe Deville two door with a cowl tag that has codes that do not match the car or I am decoding it incorrectly. I  have tried the GM Heritage center but they do not have the build sheets for 1973 Deville. Can any one help me?  thanks Bob
jagbuxx #12944
If you post the tag data you certainly will get a response
Frank Burns #12944
61 Coupe Deville Bristol Blue
41 Series 61 Deluxe Coupe 6127D Black
08 STS 3.6 1SC  Thunder Gray
16 GTI Gray
03 T-Bird Black
19 Tiffin Phaeton 40AH
07 Corvette Blue
20 MB S450 White
"Whatever the occasion, there
is no better way to arrive than in a Cadillac.
Robert666
Hi, please see photo of cowl tag.....thanks Bob
Eric DeVirgilis CLC# 8621
TR 351 - Black Leather
J - White Vinyl Roof
19 - Sable Black
Can't help with much else.
Robert,
My best guess is that you have a 1973 Coupe deVille Built in the Detroit factory on the 4th week of March (1973).   The car was Sable black with a white vinyl roof and had:Tinted Glass, Air Conditioning, Wear window defroster, 6 way power front seat,electric trunk opener, Automatic level control, an AM/FM signal seeking Radio.
That's my best guess.
Robert666
Hi Greg, thanks for your help. Does it also asks for a sun roof with the "s"  ? But the problem is it shows no sign of self leveling any where and no sign
of sun roof. Is that possible? Also white top on black seems odd to me. Is it possible that is incorrect? thanks Bob
Robert666
Hi, is it possible the tag is marked incorrectly? There is no sign of level control or sun roof.....thanks
Why is data tag fastened with screws, should not rivets be used?  Did Cadillac switch to screws at some point, as my 1970 has rivets?  Also generally the black under hood spray does not entirely cover the tag, but just around edges?
936CD69
Scot, I have seen many with screws. Robert, I suggest contacting member Tom Hall, who extensively researched these cars for several years before completing the Authenticity Manual for 71-76. He may ask for a small donation to the CLCMRC, but his wealth of information is worth it
Craig Brillhart CLC# 26217
CLCMRC Benefactor #302
jagbuxx #12944
Attached is the tag from my '76 Coupe and it is screwed on. My ' 70 and '61 are both riveted.
Frank Burns #12944
16 GTI Gray
03 T-Bird Black
07 Corvette Blue
20 MB S450 White
RobW
#12
S 1971-76 remote trunk release with pull down
L 71-74 power door locks for 2dr car
F 71-76 right side rearview mirror
K 71-74 automatic climate control
I 71-76 stereo speakers
B 71-76 rear window defogger
C 71-74 Lamp monitors
This would be a Detroit car. Linden, NJ "E" cars didn't list most options.
nothing odd about a black car with white vinyl. it was actually quite popular in 73 mostly on GM's mid-size cars, cutlass, regal, GP, etc
Rob Wirsing
Robert666
Thank you all so much for your answers. I do see mounting holes for a compressor on the left inner fender but
zero indication of a sun roof. I think that is what the " S " is calling out on the tag .
Robert666
Wow, your Good Rob..... I thought the S was Sunroof..... you guys are great ! Thanks....
Robert666
Hey how about the EAY ? .... thanks
RobW
E 71-74 soft-ray tinted glass
A 73 only power antenna
Y 71-76 6 way power seat adjuster with A52 or A65 front seats
Rob Wirsing
Robert666
