Service/rebuilding the vacuum door lock setup - 1960 Eldo
Started by Hank66, December 16, 2016, 01:35:35 PM
Hank66
Hello folks! Does anyone know of a rebuilder for the vacuum door lock setup on a 1960 Eldo?
Thanks!
Hank66
quadfins
What are the symptoms?
I removed a system from a '62 and transplanted it into my '61, so I might be able to offer some advice.
Jim
Jim Eccleston
1961 Coupe de Ville
BATILAC
Senior Crown
DeCou Driving Award x 4
Hank66
Jim, thanks for the reply!
One of the lock "mechanisms" is not holding vacuum. Need to find either a replacement or someone to rebuild. Ideally, if I can find someone to overhaul the system I would prefer to do that.
