Hood Clips for Pad Under Hood 1960
Started by Scott Halver, December 27, 2016, 06:49:32 PM
Scott Halver
Hello,
I'm buying a new hood pad for under the hood.   The vendor asked me which clips I wanted to fasten the hood pad ?     I thought the pad was just glued, but maybe the correct procedure is to use some type of clip ?
Thanks for any help, SHalver 1960 Eldorado Seville CLC #24920
1960 Eldorado Seville, Grandfather Bought New
1970 Corvette Convertible 350/350
David Greenburg
Scott:
I do not believe clips were used in these cars. Mine is glued,with no clips.
David Greenburg
'60 Eldorado Seville
'61 Fleetwood Sixty Special
Scott Halver
Hello David & Brian,
Thank you for your responses.................  just didn't know and when the vendor asked about "clips" I was at a loss.   I will use glue !
Take Care, Scott
SHalver CLC#24920
Eric DeVirgilis CLC# 8621
Spray adhesive is what is needed for the job.
Make absolutely certain the hood is 100% cleaned of oil and grease.
