1993 Eldorado steering wheel swap with 2002 eldorado
Started by Tonyv_73, January 09, 2017, 07:07:30 PM
Tonyv_73
I have a 1993 eldorado with the ugly square airbag, can I fit a 94-02 steering wheel with airbag easily?
1963 Series 62 Convertible
1965 Eldorado
1966 Calais Sedan
1970 Fleetwood Brougham
1970 Wildcat
1970 Coupe Deville
1973 Eldorado Convertible
1974 Coupe Deville
1976 Coupe Deville
1981 Eldorado Biarritz
1985 Eldorado Commemorative Edition
1991 Brougham
1993 Eldorado 4.9
1996 Fleetwood Brougham
2006 XLR
2006 DTS
2014 XTS
936CD69
First thing you would need to determine is if the SIR coil (clockspring) is the same part number for the later years, If not, the steering wheel/airbag will not interchange. If you are not positive, do NOT attempt it. Exploding air bags are not fun, and in fact are quite dangerous.
Craig
Craig Brillhart CLC# 26217
CLCMRC Benefactor #302
Series75
I replaced the square bag/wheel in my 93 Allante with a 99 style, along with the more attractive wood/leather steering wheel some 10 years ago with no problem post install.   The yellow plastic connector was of a different size so that needed update.   Horn works fine.   Now the big question "will the airbag deploy in a crash?"   Don't know, so beware.   Then again, I'm not 100% confident the airbag will deploy on my original 27 yr old STS either.   Tom clc6866
Eric DeVirgilis CLC# 8621
Quote from: Tonyv_73 on January 09, 2017, 07:07:30 PM
Unless the wheel/air bag assembly is excessively worn, I'd just leave it alone frankly. It could be opening a can of worms plus it's preferable to keep the car as original as possible.
One man's opinion.
Series75
To Eric's point....my original ugly Allante wheel is resting without incurring normal wear and will return to the column when the car goes for sale.   In the mean time I really enjoy driving the wood / leather wheel.   It's not a complex process to swap out and well worth it.  One owners opinion.  Tom clc6866
