Mike,For the 1969/70 Cadillacs it even states in the shop manual that this must be done to remove upper two bolts, the clearance is too tight and only way it will happen. You know that Cadillac dropped the body on the chassis during assembly, so this was their answer to the issue (at least they knew about and published it in shop manual). This was not a problem on the 67/68 Cadillacs I gather from your question. It is not a big deal, just adds an half hour to the job. My experience was same as yours, a few squeaks removed, slightly better, but not wow!, this makes all the difference in the world. Glad I did it, the replacements will outlast me. The upper front control arm bushings in front just do not last at all, never seen an original set in good shape.
As said in a previous post you need a hydraulic press. I have bought a bushing installation/removal tool as I don't have a hydraulic press available. I'm planning to change my bushings in the spring using this set:http://www.ridetech.com/store/bushing-installation-removal-tool.htmlHopefully that will work.
How did we get from the rear bushings to the front control arms? Dragging out threads like this is confusing to a reader why is following the subject line. Greg Surfas
