1940 LaSalle rear gravel shield installation
Started by Bill Bickle 15098, February 10, 2017, 11:15:48 PM
Bill Bickle 15098
I have the rear gravel shield which extends along and under the back of the car.  How was it fastened?  Is there a metal strip along the whole length of the rubber and then bolted to the body?
1927 (7400) and 1940 (5267) LaSalles; 1949 Cadillac 6107
tturley
Might is attached with bolt- fender washer and nuts
Member # 28929
1940 Lasalle model 5019
1995 Ford F-150
2015 Buick Enclave
Brad Ipsen CLC #737
This has some very special hardware for mounting.  The backing strip has sheet metal type sets stamped in it.  They must also be hardened to be strong enough.  The strip itself is about 1 inch wide with a 1/4" up leg on it to make it more rigid.  The rubber has about a 1 inch lip on it.  This goes on top of the body edge at the very bottom of the car.  Then the backing strip goes on top of this.  The "bolts" are sheet metal hex head screws with a medium large washer.  The head rest on the car body (upside down) and goes through the rubber and screws into the backing strip.  I am sure this is confusing without a sketch or picture but I don't have time right now to do either.  Out for the weekend.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
1940 Cadillac 60S Limo
Dan Paige
I would appreciate any help installing the gravel guards on my 1940 LaSalle.  The fender has several oblong holes and I know steel rubber has a steel backing to the reproduction gravel guards, but I do not know how to attach them.
Thank you in advance.
Dan
Proud owner of my first Cadillac LaSalle.  1940 5219.
