Sometimes little things hold up a restoration. Looking for a 1956 hose "T"
Started by johnregrus, March 15, 2017, 05:13:40 PM
johnregrus
I can't start the engine of my 1956 yet because I can't find something as simple as a heater hose "T" fitting that connects three heater hoses together in the engine bay just behind the brake booster on drivers side of the car.
I've searched the forum for previous discussions on this part and someone may have described it as a "Y" fitting or I may be mixing the part up with some other.
Attached is a drawing of what I'm looking for as well as a photo of where it is supposed to be installed on the car.
Someone told me that they were made out of tin and not copper and just rusted away.
Does anyone have any idea where I can find this fitting? The problem is the size of the openings 5/8"x5/8"x3/4".
Thanks for any help.
1958 Series 62
Mike Baillargeon #15848
Maybe make one out of copper water pipe and fittings.
I think 1/2" copper pipe fits nicely into that 5/8" hose.
Get a 1/2" "T" at home depot and solder it together......make the "T" a little longer on the 3/4" side and double clamp it.
Lets get that 56 Biarritz up and running!
Mike   #15848
Baillargeon
#15848
Caddy Wizard
#2
Hmmm, I definitely have a T fitting that looks like that somewhere in my stuff.  But I am not sure if it came off of a 54, 55 or 56.  And I think it was all 5/8, but maybe it is the one you need and has the 3/4 end.  I will see if I can  find it tonight.  The difficulty is that I moved from one house to another and so what was hard to find in my stuff is even more of a  challenge...
Oh, and yes, these T fittings are not copper.  They seem to be some sort of zinc alloy or aluminum alloy.
Art Gardner
1958 Eldo Seville (2/3 done)
https://www.amazon.com/APDTY-911533-Heater-Hose-Replaces/dp/B00CMWINHG
It plastic but if you don't have any...
Fancy would be to get one out of SS.   Probably easy to make out of SS tubing and TIG weld.
Baillargeon
#15848
Caddy Wizard
I found my T's in the basement, but they are 5/8 at all three ends.  They are made of some sort of alloy and have a barb on each end to hold the hose.
Sorry I don't have what you need...
Art Gardner
Caddy Wizard
There is a guy who just posted on the For Sale forum that he is parting out a 56.  Check that out...
Art Gardner
J. Gomez
John,
Just one small correction, the one on the firewall which is for the inlet to the two side heaters is the “T” type and the one for the outlet from both heaters which is at the left side fender (driver side) next to the P/B booster is the “Y” type.
Both have the same fittings 3/4” and 5/8” and they are pewter alloy as others have stated above.
Good luck..!
J. Gomez
CLC #23082
cadman56
John,
I think I have a couple of spares of that "Y" fitting.  I will look and let you know.  It is not plastic, tin, or copper.  It is pewter or pot metal.  they corrode badly on the inside.
I will let you know by this evening.
My email is:  lblanchard6@cox.net
I just got my 56 Seville started last week.  New PS steering gear, idler arm, and heater cores.  No leaks.  YAY!
Larry
1967 Cadillac Eldorado (sold)
Larry Blanchard CLC #5820
cadman56
