1930 Radiator Removal
Started by g8kpr, March 25, 2017, 08:10:55 PM
g8kpr
Any tips on removing the radiator on a 1930 Cadillac?
It looks like you need to remove the hoods
remove the support rods
remove the 3 nuts on each side that hold the support
remove the two screws at base
does it just lift out at that point?
Do you need to remove the headlights ?
any tips or tricks would be appreciated.
Mike Baillargeon #15848
you got it R., just disconnect the radiator hoses and it should just pull straight up and out.
why are you taking the radiator out?
mike #15848
Baillargeon
#15848
g8kpr
Thanks Mike
So no need to remove head lights if it comes straight out then.
It has a leak about halfway down hoping to have it repaired.
The radiator is heavy so get ready for that , but the headlights aren't involved.
My radiator is held on by that V bracket at the top bolted back to the firewall and the 2 big bolt setting pins on the bottom.
Remember... heavy, get stuff out of the way and go straight up with it.....gota clear that fan.
Mike  #15848
Baillargeon
#15848
Chris Cummings
How are you getting the radiator repaired?
Chris Cummings
g8kpr
Is there something I am missing?
Are you not able to get them repaired or re-soldered where leaking like a normal radiator?
m-mman
Not mentioned but I learned on my 29. Removed all the 'trim' first.  Cap, Chrome shell, shutters, etc.
I was shocked at how heavy these things are. There are no natural 'handles' and while it can be maneuvered around the headlights and fenders the chances of hitting & scratching something are high.
Anything that can lighten the load is worthwhile. I pulled mine by myself <whew> but it really should have been with 2-3 people OR with a engine lift device, especially to avoid damage.
1929 341B Town Sedan
1971 Miller-Meteor Lifeliner ambulance
Other non-Cadillac cars
Near Los Angeles, California
CLC #29634
WOW J. !
I can't imagine pulling the Radiator by myself.
Even with 3-4 guys, think where everybody has to stand to lift it up and out.....fenders, motor everything is in the way.     It's a tough job without a small overhead crane or a forklift with a boom.
Mike  #15848
Baillargeon
#15848
Joe Konarowski
Very difficult to repair a honeycombed rad. You may have to seal off that one tube. I had a bad leak in the centre also and used a rad sealant five years ago and no problems yet. I drive in on tours in Canada and US so it is getting a workout.
