Door Jamb Covers Specifically 1968
Started by Highwayman68, March 30, 2017, 02:21:50 PM
Highwayman68
Can anyone confirm if the plastic door jamb covers are the same for four door cars and two door cars. I am referring to the small cover in the attachment.
1968 Fleetwood Purchased in 1981
cadillacmike68
Are you referring to the two little round dots in the pic? This is the front of the front door - correct? It should be the same on all the RWDs that year. The bigger piece is metal not plastic - at least on my car it is.
"Cadillac" Mike
DeVille68
Hi
My 68 Convertible has this plate that you show.
I did not find exact information but I am guessing that the parts are the same for the front door, because the door hinge and cowl is the same.
I found something in the numbers catalog, but I am not sure if this really relates to the part you show.
Group:
10.778  Conduit - cover, door wiring harness or vacuum hose
Part:
66-68 ALL  4479837   Conduit, front door
The part for the rear door is different
66-68 Sedans  4479840   RH or (4479841) LH conduit, rear door.
Best regards,
Nicolas
Highwayman68
Thanks, I figured they should be the same.
