valve cover gasket
Started by 62boat, April 13, 2017, 08:03:13 PM
62boat
does anybody know if they make valve cover gaskets for a 62cdv 390 made from rubber and not cork? if so could you provide a name or place to find them. thanks
s.karatka
Jeff Rosansky CLC #28373
I got mine from Napa.... 472 tho.
Jeff Rosansky
CLC #28373
1970 Coupe DeVille (Big Red)
1955 Series 62 (Baby Blue)
Dad's new 1979 Coupe DeVille
Caddy Wizard
Not aware of rubber gaskets.  But I have had good luck with "BEST" brand valve cover gaskets ("BEST" seems better than Fel-Pro, in my experience -- sorry for the pun, couldn't resist...)
Art Gardner
1958 Eldo Seville (2/3 done)
Jon S
Jon
1958 Cadillac Sedan De Ville
1981 Corvette
2004 Mustang GT
grandads59
Have used them in the past, and the're great.  I'll be darn if I can find them.
Jon Hartwell
SixDucks
I used cork FELPRO gaskets on my 390. My practice with stamped steel valve covers is to coat the gasket in a very thin film of RTV. Allow enough time to cure completely.  Then adhere the gasket to the valve cover with a few strategically placed dabs of RTV.
This allows for a gasket that never dries out, always maintains a good crush, and seals less than perfect mating surfaces. I have never had any residuals to clean off the cylinder head when removing the valve cover.  If you ever need to remove the gasket from the cover, you'll only need to contend with the SMALL dabs used to adhere the gasket.
Terry
Current:
1941 coupe
1962 Fleetwood
1988 Brougham
Previous:
1956 Series 62 Sedan
1963 Fleetwood
1975 Fleetwood Brougham D'Elegance
1989 Brougham
