1976 Electric Trunk Release
Started by Chas, April 20, 2017, 12:51:09 PM
Chas
I'm in the process of installing a factory 1976 trunk release in a CDV that did not originally come with one. Question: Did the wire run up the left hinge and continue on inside the left side of the trunk lid, or did it run up the right hinge and continue on that side? Thanks in advance!
1967 Coupe DeVille
1970 Coupe DeVille
1976 Coupe DeVille
1983 Coupe DeVille
1977 Harley Cafe Racer
1991 Harley Fat Boy
1957 Harley Hardtail
1949 Lusse Bumper Car
If you're 25 years old and not a liberal, you have no heart. If you're 45 years old and not a conservative, you have no money!
I would run it up the side the button is on, if cabling is convenient.  Bruce Roe
Chas,
Most of the ones I have worked on come up on the driver's side.  There is a major wire run under the carpet on the driver's side in a plastic sheath.  If you remove the sill plate on the driver's side and pull up the carpet you will see it.
