67 Eldorado A/C transducer location ?
Started by jerryjansson, April 30, 2017, 03:00:11 AM
jerryjansson
Working on the A/C / climate - system in my 67 Eldorado. Previous owners have fiddled around with the vacuum-hoses and we are trying to get everything back where it belongs.
But we can not find the A/C transducer !!!!
Maybe it's hidden somewhere or it has been removed ?
Anybody out there who knows where it should be placed ?
Over and out !
Jerry J
Jerry Jansson
Stockholm
Sweden
currently 67 Eldorado, previously: 1957 Eldorado Brougham #284, 1959 Seville #975, 1960 Eldorado Brougham #94
Glen
From the 67 shop manual.
Glen Houlton CLC #727
CLCMRC benefactor #104
DeVille68
The transducer is mounted on the passenger side firewall under the dash. If you crawl under the dash you should see a mounting location with two screws (attached to the firewall) just where the carpet ends and the insulation of the firewall starts. The vacuum hoses should be routed to the right, over and then to the A/C Dash unit and out to the power servo.
jerryjansson
Thanks for the info ! On my way over to the garage to see if its still there ;-)
Have a great weekend and come to think of it, have a great life ;-)
Jerry J
Jerry Jansson
Stockholm
Sweden
cadillactim
I believe the Eldo transducer is mounted just under the glove box door on the dash frame. Not on the firewall like the RWD models.
Tim
Tim Groves
jerryjansson
Found it !
Now have to find some time to see if it works properly.
Thanks all again !
Jerry J
Jerry Jansson
Stockholm
Sweden
