1957 Ground from battery??
Started by 60eldo, May 15, 2017, 10:33:06 AM
60eldo
  On my 57 the neg from battery attaches to the frame, is that OK or should it go to the engine block. I also have a braided ground from engine to firewall,,,,correct??
Jon. Kluczynski
Walter Youshock
Correct.  There should be two braided straps from the had to cowl and another strap from the starter to frame.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
60eldo
Jon. Kluczynski
In a nutshell, you should be able to trace short, heavy conductors
directly from the battery neg to the engine block.  Bruce Roe
Dan LeBlanc
Dan LeBlanc
