1993 Allante radio
Started by Cadman53, June 09, 2017, 12:15:19 PM
Cadman53
Radio works and has power so it is not a fuse.  Cassette player and CD both work and sound fine so I don't think it is the audio box in trunk.  All I get is static on radio but the station tuning and scan work.  It just won't pick up any stations.  Could the antenna internally be bad and if so , what can I do to bypass the current antenna?
James Landi
As you know, the trunk mounted antenna unit is easily reachable in the trunk--- you might wish to consider the possibility that there is no continuity between the antenna "staff" and the input cable to your radio.  I am unsure about how the input cable attaches to the power antenna, however, if it's simply an easy off plug and socket arrangement, than testing the antenna for electrical continuity would be a simple matter of using a multi-meter to check between the antenna cable connector on the power antenna and the antenna staff.  No continuity, then no signal  is going into your radio, so, in that case, the antenna is the problem.
Hope this helps,  James
