Which gas, octane vs ethanol? 331
Started by bullet bob, June 20, 2017, 07:46:25 AM
bullet bob
I can't find any 93 octane fuel around here that is non-ethanol. My choices are either 93 w/ethanol or 90 "pure". I'm leaning towards the 90 pure but would like your input. Fuel pump has been professionally rebuilt. Thanks all. Bob
Honda Goldwing 1800  "I don't need no stinkin' map, I've still got gas"
cadman56
I started using EO87 in my 91 Brougham and was thrilled at how much smoother the engine ran and power was increased also.  The wife has to do the driving and she even remarked at the difference.  See what others may say but I would give the pure gas a try.  Larry
1967 Cadillac Eldorado (sold)
Larry Blanchard CLC #5820
Caddy Wizard
The 331 runs well on regular and doesn't need high-test fuel.  In fact, it won't help the engine run better at all.  Non-ethanol fuel (regular grade) is best for the 331, IMO...
Art G
Art Gardner
1958 Eldo Seville (2/3 done)
bullet bob
Appreciate that Art. The memory's not what it used to be, but I thought the 331's required 93. I suffer from CRS!
Caddy Wizard
No worries!  The 331 engine started out at something like 7.5:1 compression and increased over the years (starting with 52, i think).  They increased the compression ratio, while keeping the displacement the same, by decreasing the volume of the combustion chambers in the heads.  With the introduction of the 365 in 1956, the engine went to about 10:1 compression (maybe 10.5) and then needed hi-test fuel for sure.  The last 331, the 1955, had a compression ratio of about 9:1 and should be okay on regular fuel. Certainly, the early, lower-compression 331s from 1949-51 don't need hi-test.
Art Gardner
T J Lankes
You may already have this site for locating non-ethanol stations but here it is just in case you need it:
https://www.pure-gas.org/
D.Yaros
Regular worked just fine for me in my 1955 331 c.i. engine.
Dave Yaros
CLC #25195
55 Coupe de Ville
92 Allante
62 Olds
bullet bob
Quote from: T J Lankes on June 20, 2017, 01:59:19 PM
Thanks. I do have that. The only thing around here is at the lake. 90 octane. $3.79/gal.
Jay Friedman
90 octane is fine.  My '49 with a 331 runs perfectly on 87 octane non-ethanol fuel.
1949 Cadillac 6107 Club Coupe
Decatur, Georgia
CLC # 3210, since 1984
