I visually inspected the timing chain and set the timing at 6 degrees before TDC while idling at 600 rpm. Fuel tank is clean, carburetor appears to have been worked on just before my acquisition and performs very well. I did dial in the air/fuel mixture, but that's all I've done with that.The car runs smoothly at idle but under load spark knocks like you wouldn't believe. At first I thought maybe it was carbon build up so I hit the highway for about 100 miles with it, but the more I drive it, the worse it gets. I am pretty much out of ideas... The car is basically undriveable as is and I am afraid the engine will be damaged if I run it anymore the way it is. It does not seem to lack for power, but I am wondering if I have some restriction somewhere causing higher engine temps. Any help would be greatly appreciated. Thanks, Marc
