All Cads
Author Topic: rewiring 1939 Lasalle tail lights  (Read 575 times)
Offline HFDJR1959
  • Name: Herman Dick
« on: June 25, 2017, 10:27:26 PM »
Any advice how to take apart the bulb assembly and rewire.  I believe I have a short within the bulb housing.  Seems like either the parking light or the brake light wire insulation has disintegrated  around the little springs that give tension to hold the bulb in place.  If the springs rub against the bulb housing then there would be a short.  The housing seems to be pressed in place, so I don't want to mess it up.
Thanks,  HD
CLC Member 30062
1939 LaSalle 2 door coupe
Offline Steve Passmore
  • Name: Steve Passmore - Sadly Deceased
Re: rewiring 1939 Lasalle tail lights
« Reply #1 on: June 26, 2017, 02:43:07 AM »
Repaired dozens of these. If it's not the wire fraying then the small Bakelite bases may be broken.  These bases with their wire are available. 'Bobs' sell them for the twin or single connectors.
http://bobsautomobilia.com/electrical/page-4/?features_hash=1-1-187-USD
Offline HFDJR1959
  • Name: Herman Dick
« Reply #2 on: June 26, 2017, 08:48:29 AM »
Thanks Steve,  I give it a try.
CLC Member 30062
Offline Jay Friedman
« Reply #3 on: June 26, 2017, 01:27:42 PM »
Another vendor that sells parts to restore / rewire tail lights etc. is Restoration Supply, Escondido CA.  www.restorationstuff.com
I've redone several lights of all kinds using their stuff.
1949 Cadillac 6107 Club Coupe
Decatur, Georgia
CLC # 3210, since 1984
All Cads
