Decoding question 1972 Eldorado Convertible
Started by Bill Young, August 23, 2017, 10:57:59 PM
Bill Young
I own a 1972 Fleetwood Eldorado Convertible Vin # 6L67S2Q405116. Body Plate says , 72-69367 FWD 001605 , 09D , Paint 73A , Trim 454 , Top A , ACC. AM6 EXVSL KRB CJ. What I don't understand is X , my car does not have track master. What is S?. Finally when disassembling the seats to replace the Leather jammed into the passenger seat frame was this build sheet. It starts out Broadcast Seq. 185 Then Mo. 01 and Day 01. My body plate states 09D which would be build date 4th. week September 1971, I don't get it. Finally on the right below PP it has 3?
D.Smith
I've given up on trying to decode 1970s option codes on the body tags.   They never match up.  There were too many code changes in that decade.  Plus sales codes didn't always match option codes,  etc.
It is far easier to decode 60s tags.   But even then not all options are stamped on the tags.   A build sheet found under the seat is your best bet to see how your car was made.  And it is hit or miss if you'll find one.
Eric DeVirgilis CLC# 8621
#2
S - Eldorado (500 cu in) engine.
R - RWD (472) engine.
Bill Young
Thank You for that Eric. I appreciate your help.
Tom Hall 7485
If you buy the Class 25 Authenticity Manual, you will learn what "X" is on the body ID plate, along with many other early 1970s Cadillac body plate codes.
Tom Hall, CLC Member 7485, Lifetime member since the mid-1990s.
