Fleetwood Questions..
Started by William65 CLC#30475, August 30, 2017, 08:33:37 PM
William65 CLC#30475
Hello members i was in my out building today looking at the many FWB parts i have saved up and this came to mind, i do have a spare 4L60E transmission that came from the (94 FWB) (in the garage). This is the one that i rebuilt the front end from it's previous owner, who had a minor accident with it.
Question is will this transmission bolt up to the (1st GEN) 350 TBI Engine in the 93 FWB, if i'm correct they did make some changes in the transmissions between 93-96...I have heard that the Spline count could be different on the input shaft..a little feedback would be great.
#2 This weekend i should be firing the 93 FWB after all the work is done, i did REPLACE the Temp sensor (top of the intake manifold) and the Temp switch down near the exhaust manifold, so if i should get another temp light (coming on again) should i start to look at wiring diagrams or, have the PCM checked?
Please note..ALL relays were replaced, fans are in working condition, fuses are in check, i used a IR thermometer and the temp was around 210 f off the top radiator hose, and if i remove the temp sensor connector both fans do come on (this is normal) again feedback would be great..
Here is an updated picture of the 93 FWB "with no snow in the picture" it's almost ready for the garage..
1993 Fleetwood Brougham
1994 Fleetwood brougham
and many others in the past..
Chris..
Does the 93 have an E?    I had a 93 Roadmaster that wasn't an E so there was an overlap period where they used both.
