1955 4" heater hose clamps
Started by 5390john, September 05, 2017, 03:18:19 PM
5390john
Anybody know if original, or something close, 4" ventilation hose clamps are available? These are for the 4" diameter hoses that connect to the ventilation fan/heater box housings.
John Adams
1955 6237DX
1955 CDV "Marilyn"
"Panic Accordingly"
55hooptie
If you can't find them, you should be able to find metal hose clamps in a hardware store heating and cooling department for flex-duct. You might have to cut something down from a 6" duct clamp.
carguyblack
Here's an Ebay listing for a pair in case you can't locate locally. eBay item number:222608801290
Chuck
Chuck Dykstra
1956 Sedan DeVille
1956 Coupe DeVille (2 sold)
1957 Oldsmobile 98 (sold)
1989 Bonneville SSE
Mike Baillargeon #15848
Baillargeon
#15848
Bob Kielar
If you are looking for original Restoration Specialists and Supply have them. Part #DV-4 Clamp in 2015 they were $4.50 each. If you are restoring your car to be judged at a G.N. you only need two one on each motor side none on the blisters on the firewall so I've been told. There phone number is 814-467-9842 or go on line.
Keep Cruzin,
Bob Kielar
Keep Cruzin
1955 Cadillac Fleetwood
