40 Lasalle heater/defroster switch
Started by tturley, September 23, 2017, 08:16:28 PM
tturley
My fan will run occasionally but I have to mess with the switch. Can you take that switch apart and clean the contacts ?
Member # 28929
1940 Lasalle model 5019
1995 Ford F-150
2015 Buick Enclave
Brad Ipsen CLC #737
Yes, it can be done.  Always nice to have two when you do that.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
1940 Cadillac 60S Limo
tturley
Member # 28929
1995 Ford F-150
2015 Buick Enclave
Brad Ipsen CLC #737
Your choice but I was thinking switches.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
tturley
Ok
Is there a diagram of that switch anywhere ?
Member # 28929
1995 Ford F-150
2015 Buick Enclave
Barry M Wheeler #2189
Before you take the thing apart, why not purchase some electrical cleaner in a spray can and see if that cleans it up. I do that now and then on my window switches. Saves an AWFUL lot of trouble... The spray evaporates quickly so you can really soak the part without hurting anything.
Barry M. Wheeler #2189
1981 Cadillac Seville
1991 Cadillac Seville
Brad Ipsen CLC #737
I don't recall any parts diagram but the wiring diagram is very physical ands helps keep things straight.  Be very careful noting the orientation of parts involving the indicator light.  It is easy to get it backwards so it is on when the switch is off and off when on.  This is all assuming you have the standard heater and not the underseat heater which has 3 simple switches.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
tturley
I do have the standard heater. Did not know it head a light.
Thanks for the info
Member # 28929
1995 Ford F-150
2015 Buick Enclave
The small bulb is in the underside of the switch operating handle. Go very careful with these switches. There are two rheostats, one each side. Fracture the coil wires in these and it's game over.
