Replacing ‘61 turn indicator bulb
Started by David Greenburg, October 29, 2017, 04:54:37 PM
David Greenburg
I have a turn signal indicator bulb out on my ‘61, and despite its coverage of all other bulbs, the shop manual does does not appear to address this.  Does the bulb holder simply pull straight down, or is there more to it? Reaching up there with gentle hand pressure, I’m not feeling anything start to wiggle, and figured I better ask here before I break something.
David Greenburg
'60 Eldorado Seville
'61 Fleetwood Sixty Special
P. Manoogian
David,
You need to remove the chrome shield on the top side then twist the bulb. The shield is held in with BRASS screws so they do not rust in place. Use the correct bulb or it will be too bright on one side. If you need more help on this let me know.
Peter
1962 Corvette 327 - 250 HP Automatic Triple Black
1963 Impala SS Convertible - 283 Automatic Black Red Gut White Top
1965 Impala SS Coupe  - 502 Turbo 400 - Crocus Yellow
1974 Corvette L84 4spd Coupe - White / Black Leather
David Greenburg
Peter:
Thanks for the tip.  Turns out it was a loose wire; when I drove the car after looking at it, the signal was working.
David Greenburg
