Hi Bruce:As to the contacts in the clock, if this is a real concern, then why can thepoints in the ignition system sit for months without a problem? It's the same issue as I see it. Just curious! Mike
I'm pretty sure that this would be a Westclox movement. When something internally has failed, they go into a winding frenzy until eventually they burn out the coils. Basically, instead of winding down every 3 minutes and re-winding with the normal ker-chunk, it's winding down very quickly and rewinding more often than it should.I always add a 1 amp inline fuse to my clock circuit as to protect the coils should the movement fail. They're normally on the body feed circuit with a high amperage fuse with more than enough current to burn out the coils before the fuse blows. A quick splice in of the inline fuse takes all of a few minutes.I've been inside a few of these clocks and usually revitalize them with a good cleaning and lube if the coils test out fine. In fact, I've got a 53 clock sitting on my bench that will be going for sale soon on eBay now that I've sold the car. It works - doesn't keep perfect time, though.
It will wind down slowly, but as soon as the contact touches it starts to stutter violently. It is receiving the charge, but not holding in the cocked position.The clock in your photo looks like the 54 clock. I'll check the parts book tomorrow to make sure. Thanks for posting the photo.
