So, on my 77 Seville I replaced the radiator, hoses, alternator, belts and smog pump and a fresh battery, I have finally almost run out of the old gas and am going to put in new. So, I took it for a spin around the block and the car does not want to go over 20 mph (though it can) and that noise that I mentioned gets worse, its almost like it does not want to shift out of 1st gear and the noise is holding it back, would the flex plate cause this? Or am I looking at a possible rebuild for the transmission?
