Testing a 78 Eldo antenna
Started by Bob Hoffmann CLC#96, March 06, 2018, 07:25:11 PM
Bob Hoffmann CLC#96
I've got a used antenna. Marked 78 Eldo. It has 3 wires. How do I test it? Any help appreciated. If good, it'll be for sale.
Thanks, Bob
cadillactim
Bob
Positive to white, negative to green makes the antenna go down. Positive to green, negative to gray makes the antenna go up. Antenna will shut off at end of travel.
Tim
Tim Groves
Bob Hoffmann CLC#96
