'57 Door Conduit Question
Started by Dan Koser, March 27, 2018, 12:14:06 PM
Dan Koser
My 1957 Series 62 has "door conduits" that shield wires running from the body into the door to run the power windows. In my application, the conduits attach to the door and, when the door is shut, extend into the body. The opening in the body to receive the conduit is about 2" x 3". There are two screw holes above and below this opening in the body...my question is what goes there? Is there a piece of rubber...or ? that receives the conduit? Any help would be appreciated. Thanks,  Dan
Paul Tesone
 Dan - I had the same question myself , as I am in the process of restoring a 57 Eldo  . I could be wrong , but I think the screw holes are used to attach a block out plate for vehicles that do not have power windows , and therefore no need for a wire protector . Check out eBay item # 382335531737. Let me know what you think . Paul Tesone CLC# 6876
Dan Koser
VERY interesting Paul. I think you're right. Those are the right shape and the screw holes are in the right places. It's been a while since I took the door conduits off, and I didn't remember if there was anything that "received" them on the body side. I'm satisfied...thanks very much for that insight! Best, Dan
It's also my opinion that both holes are for the plate when the windows are not electric. None of my cars (with electric Windows)  have/had a rubber seal at this location.
I'm not sure, but this question came some time ago.
cadparts58
 That is exactly what the holes are for. One of the many 57-58's I have taken apart had manual windows. I still have the block out plates from that car.
Frank Puma #10721
