37 lasalle 50 u joint
Started by sly37, March 27, 2018, 04:13:04 PM
sly37
Would anyone know where to get the metal lock tabs for the u joints? They bend up around the bolt heads.
Must be somewhere in the US selling them as they have them in Aus. Have you tried one of your Nappa stores?
http://www.rarespares.net.au/rarespares/ProductPage.aspx?product=CP1129
sly37
All the parts stores around here as soon as I say 1937 they have a deer-in-headlights look. Needless to say I'm not had any luck with that.
I'm sure these guys in Aus would send them if you get desperate. Living here in the UK we have to have every little sent across the pond.
Jay Friedman
Those tabs are hard to find,though I've sometimes seen them included in new u-joint kits.  If you can't find any, a good substitute is ordinary lock washers with a dab of Loctite.
1949 Cadillac 6107 Club Coupe
Decatur, Georgia
CLC # 3210, since 1984
Glen
Its been years since I worked with those locking devices.  If you cannot find them consider tab washers.  The long tab bends over the edge of the item and the short one bends up against the flat of the nut.
Glen Houlton CLC #727
CLCMRC benefactor #104
