What is the wire by my distributor for on 1970 Coupe deville?
Started by Davidazcona12, April 07, 2018, 07:06:22 PM
Davidazcona12
Hi my name is david and i was wondering if anyone can help me find the proper location for the loose wire?
Thank you
Looks like the AC compressor clutch connection.
Quote from: "Cadillac Kid"  Greg Surfas 15364
Looks like the AC compressor clutch connection.     Greg Surfas
It certainly does.  Do I see a bit of a diode wire on the other
end, common on compressor plugs?  And probably one wire
goes to ground, or a compressor switch.  Bruce Roe
Just took another look and you can see the compressor clutch is disconnected.
cadillacmike68
The connection is right there on the far left side of your pic.
"Cadillac" Mike
Glen
It is probably disconnected because the compressor pully bearing is seized.   Easier to pull the plug than to replace the bearing especially if the A/C was non operational when it happened.
Glen Houlton CLC #727
CLCMRC benefactor #104
cadillacmike68
^^ Yeah, don't connect it if your pulley is seized. That'll be a quick end to your 59.5" belts.
"Cadillac" Mike
