Author Topic: Front Disc brake conversion with stock 52 cadillac wire wheels  (Read 650 times)
Offline longhornlarry
  • Name: L.W. Smith
Hi,
My 52 Cadillac convertible has stock Cadillac wire wheels. Anyone had any experience with converting front drum to disc brake with the stock wire wheels,clearance etc.
Larry W Smith
aka longhornlarry
Offline Carl Fielding
  • Name: Carl Fielding
Re: Front Disc brake conversion with stock 52 cadillac wire wheels
« Reply #1 on: April 10, 2018, 03:21:33 PM »
Hey Longhorn' : are your present front brakes shot and in need of major work ? If not , might be a better idea to just put a dual chamber master cylinder in it. Unless you are going to drive your '52 harder and faster than I used to do when I was a leadfoot kid moving '39s , '49s , '57 , '62 , and of course my '65 Eldo rolling on pumped up Michelin Xs , slipstreaming Porsches downhill on fast , winding mountain roads , I think you will find your brakes at least adequate as they are. You don't anticipate towing heavy trailers with it over high mountain passes , do you ? In that case , and if you actually DO drive harder and heavier than I used to do in my old Cads , you ABSOLUTELY MUST CONVERT TO DISCS !    Please drive safely. I might be coming around the next corner headed right at YOU !     - Cadillac Carl
Offline cadillacmike68
  • Still crusin'
  • CLC Number: 15823
  • Name: M Santos
« Reply #2 on: April 11, 2018, 01:35:28 AM »
Do you have access to a 70s or 80s full size RWD? If so try to test fit one of your wheels to the front hub. The Cadillac / GM single piston sliding caliper didn't really change its size from the first 1968 ones to the last 1996 Fleetwood, because they ALL take the SAME front pads.
I know the early Fords and Lincolns and Chrysler cars had larger calipers that were made smaller by 1970 or so, but not the big GM ones. I remember some wheels scraping on a 1966 Lincoln calipers way back.
If the wheel clears the caliper, you should be good to go. If they don't clear, and there's only a small amount of binding, a thin spacer, not more than 1/4 inch should work work. If you have to put a thicker than 1/4" spacer, that might not be a good idea.
OR
You get a smaller caliper based aftermarket kit which may or may not have enough stopping power for the heavy 1952 Cadillac.
« Last Edit: April 12, 2018, 08:23:03 PM by cadillacmike68 »
"Cadillac" Mike
  • Name: L.W. Smith
« Reply #3 on: April 11, 2018, 10:05:45 AM »
Thanks for the replies. Will keep you posted on project.
Longhornlarry
  • Name: L.W. Smith
« Reply #4 on: April 22, 2018, 03:15:50 PM »
  • Name: L.W. Smith
« Reply #5 on: April 22, 2018, 03:22:11 PM »
OR
Offline bcroe
« Reply #6 on: April 22, 2018, 07:15:06 PM »
Quote from: longhornlarry
Longhornlarry
Front drums may be fine driving to the grocery store.  They did
some really scary things to me when wet.  Stick with the project.
good luck, Bruce Roe
