'76/'79 Seville rear leaf spring shackles
Started by Sublime Elegante, April 26, 2018, 12:26:16 PM
Sublime Elegante
Has anyone attempted to replace the rear leaf spring shackles on a '76/'79 Seville? The original bushings have quite a large hole through them so they can use a thick metal sleeve. I can't find ANY new bushings with a hole through them that big.
Modern adaptations appear to use carriage bolts that have a larger diameter shank, so no sleeve?
I like to keep things original? Any thoughts?
CLC Member No. 25793
