Does 48 year old diff oil need to be changed?
Started by chrisntam, May 30, 2018, 09:38:32 AM
chrisntam
Thinking about draining / refilling the diff on my '70.  No indications of leaks, seepage or anything.
Leave it as is or change it using today's 90 weight?
1970 Deville Convertible
Dallas, Texas
ElZilchoTX
Check it. If it still has the proper viscosity and is clean (both of which I’d venture to guess would be “no”) then leave it. Otherwise it is a great idea to change it out.
Ryan Albert Donovan - CLC # 31361
62' Cadillac Sedan DeVille
Bentley
There was some discussion on this topic in one of my posts from a while back. About halfway down this thread, it goes into changing the differential oil. Mine's a '68, but it may be the same as your '70.
http://forums.cadillaclasalleclub.org/index.php?topic=133075.msg283468#msg283468
Wes Bentley
CLC # 30183
