1976 EFI Eldorado
Started by Joe Albanese, May 31, 2018, 01:51:57 AM
Joe Albanese
Needing answers to (2) questions..
A). On air cleaner breather housing there is a single port to receive a vacuum line. For the life of me I cannot figure out which vacuum line (or series of lines) attach to the underside of breather housing.  Please remember, this is a fuel injection configuration.
B).  Is there a replacement wiring connector to firmly attach to the actual fuel injector, as two of my injectors barely maintain a loose fitting which turns into a "miss" scenario.
Thanking in advance, Joe Albanese
Joe Albanese
Phil Weber
As far as I'm aware there is no vacuum lines on the EFI model air cleaner . Only on the carby model.
Standard motor products make a connector for the injector  # SK21.  Rock Auto normally have them but I just checked and they are out of stock.
Attached is a picture of the vaccuum for the 1976 model.
Phil
Glen
The air fitting on top of the air cleaner is most likely for the air supply to the automatic level control compressor.  Which may have been removed from your car.  Do you have air shocks on the rear of your car?
Glen Houlton CLC #727
CLCMRC benefactor #104
Phil Weber
Spot on Glen.
Joe,
Here is a picture from the manual showing the hose and fitting.
Phil
Joe Albanese
Phil and Glen,
Thanks to both of you  for your accurate responses.
Phil,
I saved the part number for the fuel injector's electrical connector from Rock Auto.  I will be ordering within the next day or so.
Glen,
Over the winter I repainted and replaced the "Electronic Fuel Injection" decal on the top cover of the air breather assembly.  That is when I noticed the port to receive a air line on the base of breather.  When I attempted to research in the '76 manual under Emissions, there was no reference to that port.
Having owned this Eldo for the last (38) years, I forgot that when I replaced the air level system with independent air shocks around (25) years ago, I disconnected that port.  Simply put, I just forgot my modification.  Age is catching up with me..
In closing, once again I appreciate the responses and this forum.  As a long time member of the CLC, a few years back I let my membership lapse as I didn't participate in club activities.  Then I had occasion to request info within the Forum, and decided that resource alone was certainly worth the cost of CLC club membership.  So.. I've been back on board as a member in good standing.  Yes, Membership has its Privileges!
Best Regards,
Joe Albanese
Joe Albanese
Glen
Glad to help.  Do you still have the compressor and valve at the rear axle?
Joe Albanese
Glen, I actually have two compressor units   One on vehicle and one in storage.
Joe Albanese
