15hp increase from 1940 to 1941 346 flathead. How?
Started by Percy, June 06, 2018, 01:54:25 PM
Percy
Hello All,
Just curious where the 15hp increase came from. For 1940 I'm showing 135hp and then for 1941 I see 150hp. Does anyone know what changed on the engine for this increase?
I've heard that 1948 346 heads had slightly higher compression than other previous heads, maybe this is the case for 1941 versus 1940?
Percy
The biggest factor I have found is they shaved away a lot more metal around the inlet valves making better flow. Unfortunately. there's not enough casting there and they crack.
Bob Hoffmann CLC#96
The Buick Road Master & Century had 150 HP & Cadillac not to be out done.
Tom Boehm
In 1940 series 60s and 62 had a compression ratio of 6.25:1    and 135 horsepower.
In 1940 series 72 and 75  had a compression ratio of 6.70:1    and 140 horsepower.
in 1941 all series had a compression ratio of 7.25:1                and 150 horsepower.
It seems a change in compression ratio upped the horsepower. Displacement and carburetor were the same. Do any of you guys out there who know more about 1941s know of any other changes?
This ratio thing has been very curious to me over the years Tom because at one time I had a cylinder head off every year from 1937 through to 1947 on the shelf. With a straight edge and a vernier gauge, I studied every single one for size and depth of combustion chamber and they are all identical down to the last one-thousandth of an inch.
I have never understood that???
Brad Ipsen CLC #737
The 1940 higher compression was achieved by putting the LaSalle head (322) on the 346 engine.  These heads are stamped with compression ratio and engine cubic inches.  There must have been some difference.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
1940 Cadillac 60S Limo
Quote from: Brad Ipsen CLC #737 on June 07, 2018, 09:15:55 PM
One would think so Brad which is what I was specifically looking for. To confess though, I did not have a LaSalle head here.
suchan
The 1941 Buick Century/RM/Limited had 165 HP with dual carburetion.
Quote from: Bob Hoffmann CLC#96 on June 06, 2018, 07:42:02 PM
Southworth, Washington
CLC #28060
1937 LaSalle 5019 Sedan
Cars that got away:
1930 Ford Model A Roadster and AA Flatbed
(2) 1938 Buick Sedans
1942 Chev Blackout Coupe
1953 Ford F100
1955 Ford Victoria
1956 Sedan DeVille
1962 Peugeot 403
1965 Peugeot 404
1971 Eldorado Convertible
