head light switch removal, '53
Started by bullet bob, June 07, 2018, 05:28:38 PM
bullet bob
I'm in the process of removing my dash for a repaint and I'm getting ready to start pulling my hair out because I can't remove the dash head-light switch. The shaft has a flat side on it which makes me think there's a set screw, but there's not. The small part that the shaft goes through looks to be 6 sided, like an allen wrench would be. But I can't get the darn shaft out. Any ideas guys? TIA.
Bob
Honda Goldwing 1800  "I don't need no stinkin' map, I've still got gas"
G Pennington
I remember reaching behind the dash and pushing in a metal spring (on the switch), which releases the knob & shaft.  You pull it out and the mounting nut is exposed.
Gary Pennington
   1953 6267X Convertible
   1941 6267D Convertible (2 door)
bullet bob
Thank you sir. I'll play with it tomorrow. I was getting ready to get out a sledge! Again, thank you.
Bob
