1996 Fleetwood remote keyless entry / TD system went on the fritz
Started by cadillacmike68, June 13, 2018, 10:16:44 AM
cadillacmike68
The entire RKE system seems to have taken a powder on me.
I had to brake VERY hard yesterday to avoid some idiocy in front of me (didn't hit anything) but after that the remote fob buttons will not do anything. They won't lock, unlock or release the trunk. They worked fine earlier in the day.
And the auto lock - unlock when the car is taken in and out of park will not work either.
and the the security dash light no longer lights up when one gets in the car.
the 1500 page service manual says the RKE/TDM (Remote Keyless Entry / Theft Deterrent Module) in / on the rear window panel, but there is no location drawing. There is something in the trunk under the window, driver side, aluminum box about 6 inches square maybe 1.5" thick with two multi pin connectors. I got those off and reconnected - no help. There is mention of a "concealed fuse". Wonderful.
It doesn't look like anything hit it, but it might have gotten "upset" from the hard braking. Or that might not be the RKE/TDM.
I even disconnected the battery and touched the cables to clear any errors. That stuff still does not work.
The power locks work from all four doors.
This is all in section 9K of book 1 (the larger of the two books).
The chart on 9K-9 says :
1. Do the power door lock switches operate normally?
Yes -
2. Disconnect the RKE/TDM and probe terminal D1
Well, WHERE is that Module??
Is is possible that the hard braking broke the module. Does anyone know where the module is, where that concealed fuse is and how to identify pin D1?
Any help is appreciated.
Thanks, Mike.
"Cadillac" Mike
cadillacmike68
This happened AGAIN  >:( Just recently.
Last time I found the module, up on the rear deck under the lining and disconnected then reconnected it. I'll try that. I checked at the dealer last week, and of course the module itself is discontinued.
"Cadillac" Mike
