69 Fleetwood "Engine Temp" Light Stays On
Started by RC Bizz, June 18, 2018, 02:33:48 PM
RC Bizz
The engine temp light in my 69 Fleetwood came on and stayed on a couple years ago, and I'm finally getting around to looking at it. The light stays on even when the car isn't running, so I need to disconnect the battery or it will drain while the car is off.
Wondering if anyone has any recommendations for where to start looking. I've seen a few forums posts through Google searching that mention a bad sensor, bad wiring, or bad fuses, but the posts were a number of years old and I never saw if the issue was fixed in any of them. Any guidance would be appreciated.
Ryan
'69 Fleetwood Sixty Special
Eric DeVirgilis CLC# 8621
Need to replace the engine temp sensor (switch).
RC Bizz
Would that be the sensor on the driver side rear engine block that I am seeing people discuss?
Ryan
Ryan
Good possibility of a grounded wire. Eather at the sensor or in the harness.
Can it be a key switch issue? Does your key-in buzzer work when the drivers door is opened ?  Temp light also comes on with key in and drivers door open.
cadillacmike68
"Cadillac" Mike
Jeff Rosansky CLC #28373
Squirt some sort of lube in the ignition switch and then put the key in/out several times to see if that cures the problem. The switch probably thinks the key is in it.
Jeff Rosansky
CLC #28373
1970 Coupe DeVille (Big Red)
1955 Series 62 (Baby Blue)
Dad's new 1979 Coupe DeVille
Glen
Attached is the circuit diagram.
Glen Houlton CLC #727
CLCMRC benefactor #104
According to the drawing Glen provided, the warning buzzer will sound
any time the ENGINE TEMP TELL TALE light is on.  The key switch will
not do anything with the door closed, probably not the issue.
Certainly I would start by unplugging engine sensors to see if one
will turn the light off.  Given that the symptoms don't match up
(light and buzzer), I am wondering if there is another light and
sensor than those shown in this drawing.  Bruce Roe
There are two warning light to high temp on the 69/70 Caddy, one is hot block, the other measures coolant.  The light illuminates when ground is made by the sensors.  The hot block one I think is in back, the coolant one is under compressor with green wire.  Both are one spade connectors.  With engine off and battery disconnected pull each spade connector off and measure with ohm meter if the sensor spade connector is shorted to ground, if so that is the problem, ground should only be made if it is too hot.  If both sensors are OK, then look at ignition issue with key buzzer.
Only the "stop engine temperature" lamp can remain illuminated with the ignition off; coolant temp, to my knowledge, cannot.
RC Bizz
Thanks for all the replies. To answer the earlier question, the key-in buzzer does work, but only when the key is put in the ignition, as I would think it should.
Could anyone describe a rough location of where the engine temp sensor is located? I have heard driver side near the back of the block but haven't seen any diagrams or anything to get an idea of where I'm looking.
Ryan
klinebau
Back left side (drivers side) of the engine, by cylinder #8.  Behind the rocker arm cover.  There may be a single green line running to it.
1970 Cadillac Deville Convertible
Detroit, MI
Quote from: RC Bizz on June 20, 2018, 08:21:35 AM
As far as I'm aware, the buzzer and Temperature lamp always operate together. Maybe it's different in 1969...
