37 lasalle speedo issues
Started by suchan, June 21, 2018, 11:21:15 AM
suchan
My speedo was making an obscene noise and jumping all over, so I replaced the cable with a NOS unit I got off eBay. Worked fine for a while, but now it's starting to make a little noise and jump around, especially when I'm driving over 40.
What are the symptoms of a speedo needing repair? Can the speedo be causing the problem rather than the cable?
Southworth, Washington
CLC #28060
1937 LaSalle 5019 Sedan
Cars that got away:
1930 Ford Model A Roadster and AA Flatbed
(2) 1938 Buick Sedans
1942 Chev Blackout Coupe
1953 Ford F100
1955 Ford Victoria
1956 Sedan DeVille
1962 Peugeot 403
1965 Peugeot 404
1971 Eldorado Convertible
nixiebunny
There are two bearings inside the speedo that can cause trouble. The likely one is the tiny bearing that the needle pivot sits in - it's part of the spinning magnet assembly. Any bit of crud can cause it to stick a bit. When it sticks, then the needle jumps. The main bearing that the magnet spins in can also be worn. Mine was rather loose after 100k miles. I swapped in the assembly from a '58 Chevy, with some minor tweaks for the odometer.
It's possible to disassemble it yourself to clean and oil the bearing, but you need a steady hand and some clock-making tools. Best to leave that work to a professional if you don't have the skill set.
tripwire
You might also consider lubricating your speedo cable.  They dry out, get noisy and will make the needle jump.  If the cable is truly NOS it's had plenty of time to dry out sitting on the shelf all these years.
Wes in VT
Driving now:
2023 XT4 Luxury
1940 LaSalle 5229 C4D
A few I used to drive:
1976 Cadillac Ambulance
1969 Cadillac Hearse, Superior Body
1966 Buick Wildcat Hearse
1957 Ford Thunderbird x 3, 1 E code, 2 D code
1956 Oldsmobile Rocket 88 Sedan
1949 Mercury Convertible
1949 Mercury Coupe, Mild Custom
1936 Buick Special Sedan
Try loosening the knurled nuts that hold the cable to the back of the speedo. If the outer cable is too tight they can bind up the inner cable. Use very little oil as too much can wind up the cable and ruin the speedo head.  I apply some oil to a rag and pull the inner cable through it.
