1959 Coupe Deville Rear Pinion Seal
Started by gkhashem, June 21, 2018, 08:58:33 PM
gkhashem
What is involved in changing my seal? I see two part number on Rock Auto do I need both seals?
https://www.rockauto.com/en/catalog/cadillac,1959,deville,6.4l+390cid+v8,1320545,drivetrain,differential+pinion+seal,2380
I have some leaking at the rear of my drive shaft/differential. I would love to try to minimize my leaks. Car not too bad and it's been better since I have been storing the car in my heated garage in the winter. I have noticed less leaking in a controlled environment.
1970 GMC C1500
1992 Oldsmobile 98 (OCA 1st)
1996 Oldsmobile 98
Past Cadillacs
1959 Coupe Deville
1966 Coupe Deville (Sr #861)*
You do need only one, but there were 2 different outside diameter available.
