Founded 1958
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Forum Rules
Calendar
Login
Register
CLC Home
Forum Rules
Technical / Authenticity
(Moderators:
Lars Kneller 8246
quadfins
Barry M Wheeler #2189
Bill Hedge CLC 14424
Sputtering acceleration - 1959 Cadillac CDV
All Cads
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Sputtering acceleration - 1959 Cadillac CDV (Read 1480 times)
Paul
Pscarlato
on:
July 26, 2018, 01:14:07 PM »
Wondering if I could get some direction on my issue. My 59 Caddy engine idles smoothly, but when I put it in Drive and push the gas the engine feels like it's sputtering and struggling? Could this be a timing issue? A carb issue or a gas filter issue? I don't want to start tearing it apart without some logic behind doing it. Also, I feel like when the trans hits 2nd to 3rd gear, it almost feels like the engine hasn't rev'd enough...similar to driving a stick shift and shifting too early, then having to push the gas to get up to speed and smooth out. Could this all be related or are these different issues? Any thoughts would be appreciated. Thanks!
Logged
‘59 Caddy, Seminole Red with Dover White top
novetti
Re: Sputtering acceleration - 1959 Cadillac CDV
Reply #1 on:
July 27, 2018, 12:06:52 AM »
Check :
Accelerator pump fuel skirt down the carb throat
Timing needs to be checked. If not advance is happening it can cause that sympton.
Logged
54' Iris Blue (Preservation)
54' Cabot Gray (Restoration)
58' Lincoln Continental Convertible (Restoration)
58' Ford Skyliner (Preservation)
P. Manoogian
CLC #29766
Reply #2 on:
July 27, 2018, 04:46:12 AM »
My 59 (AFB) did this after being winter stored. Turned out the gas, in spite of "stabil" additive, was bad and the inside of the carburetor looked like a cesspool. Rebuilt the carb and it is fine. Pop the top off your carb and see what the gas looks like.
Logged
1959 Coupe DeVille - Vegas Turquoise
2012 CTS Coupe- Crystal Red
1970 AMX
60eldo
EVERYDAY ABOVE GROUND IS A GOOD DAY
Name: Jon Kluczynski
Reply #3 on:
July 27, 2018, 07:35:23 AM »
Mine did this yesterday. A vacume hose fell off. Also could be spark plug wires bad. Check them in dark place , running engine , get a spray bottle and spay lite mist over the wires and on dist. Look for sparks flying around.
Logged
Jon. Kluczynski
russ austin
Reply #4 on:
July 27, 2018, 02:50:10 PM »
Look at the points, condenser, coil, plugs, plug wires, carb and fuel flow.
Logged
R.Austin
CLC Number: 22443
Reply #5 on:
July 27, 2018, 03:34:46 PM »
This type of problem cannot be definitively diagnosed online.
Someone needs to evaluate the engine and it's a process of elimination.
It can literally be anything from junk in the tank, failing fuel line or blockage, carb or vacuum issue, ignition problem like points or condensor, cracked cap, wiring, weak coil, or valve train or timing problems.
You may want to take it to a mechanic to get to the root cause of the problem.
Best thing would be someone with an old school diagnostic scope.
Logged
CLC # 22443
I prefer email's not PM's rachlin@comcast.net
59-in-pieces
CLC Number: 17326
Reply #6 on:
July 27, 2018, 03:51:25 PM »
Paul - Julio - Russ.
Housekeeping:
Join the CLC
Buy a Shop Manual
Now to business:
What model is your car.
When did you get it.
When did the problems start.
Good suggestions on the carb.- unless tri-power (and gas) also look for healthy squirt from accelerator pump, when accelerator is depressed , timing , plugs, wires, distributor cap cracks/dirt (points and condenser).
As for shifting, the trans (TVP shift linkage) may need to be adjusted.
Fuel pump (filter) pressure test.
Check fuel lines from fuel tank to the carb. including any rubber lines - both lines (return line if AC car) for pin hole leases which reduce suction of fuel and its delivery.
Let us know which if any of the suggestions helped the 59 (my favorite car) to work better.
Have fun,
Steve B.
Sorry Brian - didn't see your post till hit post
Logged
S. Butcher
Paul
Pscarlato
Reply #7 on:
July 27, 2018, 05:30:29 PM »
Steve,
Housekeeping: Got the manual, will join the CLC.
Now to business: Coupe DeVille, no A/C. Got it about a month ago. It always had this unsmooth acceleration from the day I got it.
I replaced the rotor, cap, wires and plugs, but not the points or condenser. Noticed an improvement when the new plugs went in. Carb is rebuilt, few years back. Looks clean. Adjusted the TV Rod for the trans and that smoothed out the shifts. I still have to check the timing. I thought I should also check the points adjustment at the dist. cap and thought about adjusting the carb. I notice there is always a lingering gas smell, not very heavy but noticeable. I was thinking the mixture was too rich perhaps?
I still need to change the gas filter, too. Thoughts?
Logged
russ austin
Reply #8 on:
July 27, 2018, 08:38:11 PM »
Quote from: 59-in-pieces on July 27, 2018, 03:51:25 PM
Housekeeping:
Join the CLC
Buy a Shop Manual
I am a clc member....
Logged
R.Austin
Jeff Rose CLC #28373
CLC Number: 28373
Reply #9 on:
July 27, 2018, 11:36:45 PM »
Ran into this with the 55. Check your coil. When we got her, she came with the wrong old coil that didn't need a resister so someone had hooked up to a full 12 volts. Ran fine that way. I put in the correct coil for the car which needs a resister and it ran horribly. When I discovered the coil had a full 12 volts I put the resister in-line and it runs fine now.
Last Edit: July 27, 2018, 11:41:21 PM by Jeff Rose CLC #28373
Logged
Jeff Rosansky
CLC #28373
1970 Coupe DeVille (Big Red)
1955 Series 62 (Baby Blue)
Dad's new 1979 Coupe DeVille
59-in-pieces
CLC Number: 17326
Reply #10 on:
July 28, 2018, 01:48:58 PM »
Paul,
Good U R joining.
Coil - check it out - often fails if weak as the temp goes up.
Smelling gas
"Fuel pump (filter) pressure test.
Check fuel lines from fuel tank to the carb. including any rubber lines ... for pin hole leases which reduce suction of fuel and its delivery." and a possible gas smell.
Timing should be set sooner than later.
Since carb. worked of awhile back "look for healthy squirt from accelerator pump, when accelerator is depressed"
And, check for air leak under carb. at gasket to intake by spraying lightly and at a distance some "quick start" and see if engine RPMs increase.= leaks.
Happy hunting - have fun,
Steve B.
Logged
S. Butcher
Paul
Pscarlato
Reply #11 on:
July 30, 2018, 07:03:32 PM »
Just an update: sprayed the carb with a carb cleaner and she instantly ran better. Solved about 40 percent of the problem. Also found loose hose at carb and gas line, tightened that down and any other I found and that helped too. Timing is at 5 degrees per the manual. Will change gas filter next and hopefully that will help smooth acceleration. Halfway there. I’ll update after fuel filter replacement. Thanks for the help!!
Logged
savemy67
Reply #12 on:
July 30, 2018, 08:10:45 PM »
Hello Paul,
In addition to the fuel filter in the glass bowl, your carburetor may have a sintered bronze filter where the fuel line enters the carburetor. I don't have a '59, and I don't know which carburetor you have, but you may want to check if there is a filter in your carburetor in addition to the filter in the glass bowl.
Respectfully submitted,
Christopher Winter
Logged
Christopher Winter
1967 Sedan DeVille hardtop
Daryl Chesterman
Name: Daryl Chesterman
Reply #13 on:
August 02, 2018, 01:33:06 AM »
Hi Paul,
The stumble on acceleration could be due to a bad vacuum advance. You can check your vacuum advance if you have a hand vacuum pump. Pull your distributor cap and with the vacuum pump connected to the hose going to the vacuum advance, apply some vacuum and see if the base plate in the distributor starts to rotate. If your vacuum pump has a gauge, it should hold the vacuum steady and the base plate should stay where it rotates after the vacuum is applied. If the vacuum leaks down or you can't create a vacuum at all, the advance unit is bad (provided the hose to the advance unit is in good condition). If you get a good, steady vacuum, and the base plate does not rotate, the base plate might be binding and unable to rotate, thus no advance on acceleration.
Good luck,
Daryl Chesterman
Logged
Paul
Pscarlato
Reply #14 on:
August 10, 2018, 09:58:49 PM »
Following up on this, I reset the dwell angle to 30 degrees, it was off by 3 degrees at 33. Checking timing again, but what should the advanced timing be on this engine? I have initial timing at 5 degrees pervthe book. Any suggestion on the correct advanced timing? Once that’s correct I will check the vacuum— haven’t had a chance to do that yet—I misplaced my vacuum gauge!
Logged
Paul
Pscarlato
Reply #15 on:
August 13, 2018, 11:43:50 AM »
Just an update, was able to lower the idle rpm, it was idling when warm at more than 1000 rpm. Got it down to about 480 rpm - much better. Quicker response and no hesitation anymore. The carb was running very rich, tuned that down as well.
I was told I should advance the timing- it’s currently at 5 degrees. I was advised these big engines like advance. Was also advised to remove a spring from the distributor weights as well. Any thoughts on this? Yes or no. Just curious.
Logged
cadman59
Reply #16 on:
August 13, 2018, 11:57:56 AM »
I have advanced the timing of my 59 also more than the initial 5 degrees and it's running much better now. Idles smoother, far more power and it seems to run cooler. Advanced it just by listening to the engine. If you advance it too much you will hear the engine ping when the engine is under load, so you know you have to retard it a little bit.
Haven't heard about removing a spring of the mechanical advance though.
Logged
Feiko Kuiper - Netherlands (Europe)
1959 Cadillac Series SixtyTwo 6-window sedan
The most valuable antique is an old friend.
CLC Number: 4719
Reply #17 on:
August 13, 2018, 01:48:56 PM »
You might try 7/8 degrees advance and see how that works. DO NOT remove one or both mechanical advance springs, I am familiar with putting lighter springs in (which, unless you are tuning for drag racing and know what you are doing, you do not need), but have never heard of removing weight springs all together.
It would be good to go in and make sure the mechanical advance weights move smoothly and freely and possibly put a
thin
swipe of light grease under them.
You will know if your vacuum advance is working when you reconnect the vacuum hose, which was disconnected and blocked off while setting the base timing --- right?
Engine idle will increase and you will see it with your timing light.
Stop talking to Chevrolet mechanics. Small block and big block Chevys can stand more advance than the stock, slower revving, higher torque Caddy engines.
Last Edit: August 13, 2018, 01:51:15 PM by 35-709
Logged
Paul
Pscarlato
Reply #18 on:
August 17, 2018, 11:28:36 AM »
Just an update: advanced timing to about 8 degrees and adjusted the curb idle to about 550-575 RPM. Adjusted the air/fuel mixture down as well. The car runs much better now. Smoother. I’m going to drop some lead additive in the next tank of gas and see if that helps any, but I’m fairly satisfied at this point. Still adjusting the TV Rod for smoother shift,but it’s okay. Incidentally, I dropped some seafoam in the tank and sprayed some in the carb. No big smoke show— pretty mild, just a little haze for a minute or so. Didn’t do much, perhaps the carb is clean enough? Any thoughts are welcome on further smoothing it out. Btw, the timing advance is okay. Thanks for everyone’s help on this.
Logged
Print
Pages: [
1
Go Up
« previous
next »
(Moderators:
Lars Kneller 8246
quadfins
Sitemap
1
2
3
4
5
6
7
8
9
10
11
12
13
All Cads
