67 DeVille 429 fuel pump replacement question
Started by jims427400, August 09, 2018, 03:18:17 PM
jims427400
Can someone explain how I do step #3 on the fuel pump removal section of the repair manual please?
Thank you,
Jim
DeVille68
The should be a screw in the front of the crank. It should be a 9/16-18 UNF
Or you could try an hit the starter real quick
jims427400
My problem is I don't know where to index the crank to the position on step 3..  I'm just not understanding what it's telling me to do.
I've swapped out several chevy Fuel pumps and I've just removed the rod and when inserting it I put some heavy grease on it so it doesn't slide out.
Jim
jims427400
I figured it out. I loosen the 2 FP screws and click starter until the fuel pump is loosest and then remove. At least I hope that's what it means..
DeVille68
Quote from: jims427400 on August 09, 2018, 10:27:30 PM
jop, that is exactly the reason! Good that you figured it out
