2005 deville, occasional tiny hesitation at stop
Started by 55 cadi, August 17, 2018, 01:31:16 PM
55 cadi
Hello all,
My new cadi has a few little things to work on, fixed a couple, but wasn't sure about this.
At a stop, or in gear but sitting at light, it has an occasional hesitation or flutter for a second and then stops, engine still runs when it happens, when driving you don't feel or notice anything happening.
Is this a fuel injector issue, like maybe needing injector cleaner to be used?
1955 Cadillac sedan series 62
2005 Cadillac deville
l would start with a full scan, look for pending codes, many things can cause this. Not knowing the history, could need a throttle body cleaning, bad wire or plug and so on.
55 cadi
Ok, thanks,
A little more back ground, had two codes, got them fixed, throttle body boot and intake gaskets, so no more codes except airbag, believe from water on connection.
Oil looks good, trams fluid good, runs great, smooth idle except a slight lower of rpm for a sec every minute or three.
