That is not right part. The front mount is a center unit and you can see it with hood open. Make sure you have a Cadillac Factory Shop manual (on e-bay for $40 or so). That will give you a picture. Usually a front engine cover oil leak takes them out. If you replace it seal up the front of the engine well too.Since you likely have a front engine cover oil leak, replace the timing chain if it is original.I replaced a 1972 front engine mount and went thru this already. I think they have to be rebuilt, no new ones around.
