1960 Cadillac Door Panel Romoval
Started by 60eldo, September 07, 2018, 06:15:43 PM
60eldo
  I cant seem to get my door panel off to fix a sagging window. I got most bolts out but does the pull handle have to come off so that the panel can be removed?  Im mean theres 2 small screws holding it on
Jon. Kluczynski
savemy67
Hello Johnny,
My recollection from my other 59/60 GM cars owned decades ago, is that the door pull screws have to be removed. The door pull is pulling the weight of the door, and it is used constantly.  It is unlikely that if the door pull was attached only to the door panel, it would work as a door pull.
If you have the Fisher Body manual for your car, it will describe the procedure for door panel removal.
Respectfully submitted,
Christopher Winter
Christopher Winter
1967 Sedan DeVille hardtop
60eldo
  Wont come off somethings holding it on near the center top
Jon. Kluczynski
savemy67
Hello Johnny,
On my '67, I found a screw that was not called out in the Fisher Body manual.  It was hidden in the "fuzzy" at the top of the door panel.  Some panels had to be lifted straight up in order to "unhook" them from the inner door sheet metal at the top of the door.  Hope this helps.
Christopher Winter
Christopher Winter
marty55cdv
Johnny after releasing the door panel nails from the door, the inside handle, and also the door pull ,the remote mirror knob etc, you have to lift the door panel up first before pulling it away from the door.
Marty Smith
  CLC #22760
41 60 Special http://bit.ly/1Wm0GvT
55 CDV http://bit.ly/1G933IY
56 Fleetwood
1958 Extended Deck http://bit.ly/1NPYhGC
1959 Fleetwood  http://bit.ly/1OFsrOE
1960 Series 62 Coupe
1960 Sedan DeVille  4 window Flattop
63 Fleetwood http://bit.ly/1iSz17J
1964 Eldorado http://bit.ly/1Wm17GA  (Living in California now)
1988 EBC http://bit.ly/1iSACKz
