https://stcloud.craigslist.org/cto/d/for-sale-1952-cadillac/6676090158.html I don't see the car increasing in value. That's the conundrum - how much do you offer on a car, provided it's a car you like and have made a decision to buy, knowing you will enjoy it in the hobby but it's not appreciating?
Having completed a complete long hydraulic redo on my 49, I recommend you look very closely at the system when considering purchase price. It may not be the replacement of only cylinders and hoses. Over time the hydraulic plumbing can develop rust pin holes or get clogged with hardened brake fluid or rust debris that cannot simply be blown out. Then the whole car needs to be replumbed and that is significantly more work than replacing cylinders and hoses. The hydraulic pump may also need rebuild or replacement if it can't make 250psi at the cylinders. Hard to tell the overall shape of the hydraulic system if it's not pumping. If no windows are working, it's probably more than the cylinders since they don't all go out at once and one bad cylinder does not stop the others from working unless it's leaking profusely. All cylinders are available for purchase and hoses are made to order. All hydraulic plumbing is custom fabricated.
Bryan, Would your goal be to return it to authentic original condition? The interior may be nice, but it isn't very close to original. The Fleetwood did not have leather in 1952. The hydraulic rebuild is a major item, but I believe the parts are still available from Hydro-Lectric. You are fortunate if you have someone near by that can do the job. When replacing the cylinders and hoses, be sure to switch from Brake Fluid to something else -- transmissions fluid or hydraulic fluid. Brake fluid is hygroscopic.(absorbs water) and it destroys paint. The exhaust is not a problem. Maybe $600 for the pipes, mufflers, and resonators. Plus labor. The fog lights and the panels below the headlights are not authentic, and will not be cheap to replace or to have replated. I like the black with white top. If chrome and stainless are free of deflects, that is a huge plus! Of course a good engine and good transmission are pluses as well. If you wind up buying it, send me a PM and I can provide some materials and background.John Emerson1952 Cadillac Sedan 6219X
appreciating? That is never a factor to me. Appreciation is more important.I think the more important factor here is that you are on a mission to buy on a budget and are looking for a deal that doesn't need too much $ to be spent on it. This isn't that car. While it is a pretty car and will make a nice driver once sorted out, it still need a ton of $$$ to make it more presentable. Those black painted front parts that should be chromed were painted for a reason. They need rechroming or replacing. As pointed out the hydraulic window system is not cheap to fix.
