I believe the Brake Fluid Fill port is the vertical tube on the left side of the power brake unit on the fire wall.
Question:
I removed the Top Cover (with the square nut) - where should the Brake Fluid Level be at?
I did not see any lines nor marks on / in the Tube to indicate fluid level. I have read the Service Manual and not found any direction for Fluid Level.
Experienced input Requested Please!
Mark Anderson
